Versa 2 stuck on message "Data not cleared, Sync & Tried again"
ANSWERED
I broke my charger had to order new one battery ran down. I’ve tried charging it and it has a red x :cross_mark: on the face and tells me data not cleared sync and try again. My iPhone tells me it’s connected but nothing happens. Anyone ever had this problem. Help
1 BEST ANSWER
Accepted Solutions
Hi there, @Terrytrantham. Welcome to the Community Forums. Thanks for the details provided in your post about the issue with your Versa 2.
Please note the message "Data not cleared, Sync & Try again" usually appears when you performed a factory reset without first unpairing your watch from your phone's Bluetooth settings.
With that being said, please confirm if you've followed the steps below to solve this issue:
  • Unpair your Versa 2 from your phone's Bluetooth.
  • Force quit the Fitbit app.
  • Turn off the Bluetooth.
  • Turn on the Bluetooth.
  • Set up your Versa 2 again.
  • If there is no connection, restart your Versa 2.
If you can't get started with your Versa 2, usually a missing requirement is the cause. Carefully review the requirements provided in the help article Why can't I set up my Fitbit device?
Hope that helps.
3 REPLIES 3
Hope that helps.
This did not work for me because the android kept returning to the Check if Versa 2 is on page. I can, if I choose pair the devices using the Bluetooth app. I can not get past the X Data not cleared on the Versa. And so I can't sync and restart.
I have the exact same issue.  Someone pleas help us!
