Versa 2 stuck on message "Data not cleared, Sync & Tried again"
ANSWERED
My Versa 2 suddenly stopped working.  Says "Data not cleared. Syn & try again".  I keep trying but no luck.  I have rebooted the versa 2 and my phone.  Nothing.  Any suggestions?  This is my 4th Fitbit.  Almost everyone has died about a year after purchase.  I'm getting frustrated and doubt I'll buy another.
1 BEST ANSWER
Accepted Solutions
Hi there, @LM83. Thanks for stopping by in the Community Forums and already trying to troubleshoot the issue with your Versa 2 before posting here. I understand how frustrating this can be.
Please note the message "Data not cleared, Sync & Try again" usually appears when you performed a factory reset without first unpairing your watch from your phone's Bluetooth settings.
With that being said, please confirm if you've followed the steps below to solve this issue:
  • Unpair your Versa 2 from your phone's Bluetooth.
  • Force quit the Fitbit app.
  • Turn off the Bluetooth.
  • Turn on the Bluetooth.
  • Set up your Versa 2 again.
  • If there is no connection, restart your Versa 2.
If you can't get started with your Versa 2, usually a missing requirement is the cause. Carefully review the requirements provided in the help article Why can't I set up my Fitbit device?
Hope that helps.
3 REPLIES 3
Hope that helps.
Thanks for responding but it didn't work.    I get a big red "X" in a red circle.  I have an iPhone 8 plus and it has always worked before.  When I check the Bluetooth on my phone it says the Versa is connected but it will not connect to the wifi.  Every time I try connecting to wifi I see the bars and then it quickly changes to the Fitbit icon in white or green.
I'm about ready to give up.  This is my second Versa 2.  I believe this one was purchased in May of 2021 and hasn't lasted a year.  Frustrating.
LM
@LM83 I appreciate you had followed the tips and recommendations provided above.
At this moment, I’ve reached the limits of what I can do for you here on the public community forums. The best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
