01-16-2022 13:48 - last edited on 01-17-2022 10:21 by MarreFitbit
Data not cleared sync & try again. Watch not working
01-17-2022 10:22 - edited 11-02-2023 03:35
Hi there, @JeremyJoe. Welcome to the Community Forums.
Please note the message "Data not cleared, Sync & Try again" usually appears when you performed a factory reset without first unpairing your watch from your phone's Bluetooth settings.
With that being said, please confirm if you've followed the steps below to solve this issue:
If you can't get started with your Versa 2, usually a missing requirement is the cause. Carefully review the requirements provided in the help article Why can't I set up my Fitbit device?
Hope that helps.
Hope that helps.
