04-12-2022
16:26
05:53
04-12-2022
16:26
05:53
My versa 2 displays circle with X saying data not cleared sync and try again but won't sync
04-18-2022 05:54 - edited 04-18-2022 05:55
Hi there, @DCoss. Welcome to the Community Forums. Thanks for the details provided in your post about the issue with your Versa 2. @SunsetRunner Thanks for your help! 🙂
Please note the message "Data not cleared, Sync & Try again" usually appears when you performed a factory reset without first unpairing your watch from your phone's Bluetooth settings.
With that being said, please confirm if you've followed the steps below to solve this issue:
If you can't get started with your Versa 2, usually a missing requirement is the cause. Carefully review the requirements provided in the help article Why can't I set up my Fitbit device?
Hope that helps.
04-13-2022 04:21
04-13-2022 04:21
Hello @DCoss
I found a great article that helps you to resolve this very issue. You can find it here: https://www.myhealthyapple.com/how-to-fix-a-fitbit-that-shows-a-red-x-with-message-data-not-cleared/
Hopefully this helps and gets up up and running again. 😃 Happy Stepping!
Hope that helps.
04-19-2022 13:19
04-19-2022 13:19
This doesn't work with my fitbit charge 2. I tried your steps so many times but it's still the same.
Best Answer04-19-2022 14:52 - edited 12-31-2023 08:04
Hi there, @Jenny.02. Welcome on board. I appreciate you had followed the tips and recommendations provided above.
I've seen you tried reaching out to our Support Team after posting here, but your chat got disconnected. If you continue having connectivity issues, feel free to give us a call. Click here to get connected.
We hope your issue is solved soon.
