Versa 2 stuck on message "Data not cleared, Sync & Tried again"
ANSWERED
my fitbit versa 2 has an error message of data not cleared sync & try again.
I cannot get off of this screen - help please?
1 BEST ANSWER
Accepted Solutions
Hi there, @ED5593. Welcome to the Fitbit Community Forums. I'm sorry to hear that your Versa 2 is stuck on "Data not cleared, Sync & Tried again" message. I'll be glad to help you with this!
Please note the message you're receiving usually appears when you performed a factory reset without first unpairing your watch from your phone's Bluetooth settings.
With that being said, I'd recommend trying the steps below in the order listed:
  • Unpair your Versa 2 from your phone's Bluetooth.
  • Force quit the Fitbit app.
  • Turn off the Bluetooth.
  • Turn on the Bluetooth.
  • Set up your Versa 2 again.
  • If there is no connection, restart your Versa 2.
If you can't get started with your Versa 2, usually a missing requirement is the cause. Carefully review the requirements provided in the help article Why can't I set up my Fitbit device?
@LZeeW Thank you for moving the post to the Other Versa Smartwatches board for organization purposes.
Hope that helps!
2 REPLIES 2
Hi @ED5593   I moved your post to the Other Versa Smartwatch forum, a better fit for your question.  I’m sorry, but I can’t help you.  I don’t have any experience with that error.
Laurie | Maryland
Hope that helps!
