Versa 2 stuck on message "Data not cleared, sync & try again"
ANSWERED
I have this message on my Fitbit Versa 3.  I know that there was a problem with the server, but I heard that that has been resolved.  I'm still not able to sync - with that message still on the watch. How to I fix?
Thanks!
1 BEST ANSWER
Accepted Solutions
Hi there @Pres345, welcome to the Community Forums. Thanks for sharing the details about the issue with your Versa 2.
The error message you're receiving on your watch usually appears when you performed a factory reset without first unpairing the Fitbit device. With that said, try the steps below:
  • Unpair your Versa 2 from your phone's Bluetooth.
  • Force quit the Fitbit app.
  • Turn off the Bluetooth.
  • Turn on the Bluetooth.
  • Setup your Versa 2 again.
  • If there is no connection, restart your Versa 2.
If you still have syncing difficulties, see Why won't my Fitbit device sync?
I've moved your post to the Other Versa Smartwatches board for organization purposes.
1 REPLY 1
