Versa 2 stuck on message "Data not cleared, sync & try again"
ANSWERED
Greetings,
my wife’s versa 2 suddenly stopped working. The FitBit app sees it but can’t sync or update it. I’ve removed and repaired it twice.
when I try to reset it, the FitBit logo displays like normal but after a minute or so it displays “Data not cleared Sync and try again”
We’re stuck at this point.
1 BEST ANSWER
Accepted Solutions
Hi there, @GBradburn. Welcome to the Community Forums. Thanks for trying to troubleshoot your wife's Versa 2 before reaching out.
Please note the message "Data not cleared, Sync & Try again" usually appears when you performed a factory reset without first unpairing the Fitbit device from the phone's Bluetooth settings.
With that being said, please confirm if you've followed the steps below to solve this issue:
  • Unpair the Versa 2 from her phone's Bluetooth.
  • Force quit the Fitbit app.
  • Turn off the Bluetooth.
  • Shut off her phone and turn it on after 1-2 minutes.
  • Turn on the Bluetooth.
  • Set up the Versa 2 again.
  • If there is no connection, restart the Versa 2.
If you can't get started with her Versa 2, usually a missing requirement is the cause. Carefully review the requirements provided in the help article Why can't I set up my Fitbit device?
1 REPLY 1
