02-05-2021
07:25
09:51
02-05-2021
07:25
09:51
Caannot get rid of red x data not cleared screen how do you sync and try again
02-05-2021 09:51 - edited 09-29-2023 05:29
Hi there @Peggieanne, welcome to the Community Forums. Thanks for sharing the details about the issue with your Versa 2.
Please keep in mind that the error message you're receiving on your watch usually appears when you perform a factory reset without first unpairing the Fitbit. You should've unpaired the Versa 2 from your Fitbit account and phone's Bluetooth settings and then perform the factory reset. To solve this issue, try these steps in the following order:
If you can't get started with your Versa 2, usually a missing requirement is the cause. Carefully review the requirements provided in the help article: Why can't I set up my Fitbit device?
Best Answer02-05-2021 08:05
