08-31-2021
09:51
16:02
08-31-2021
09:51
16:02
How do I set the screen awake? The watch keeps saying set up Alexa, which I do not want to do.
08-31-2021 10:26
08-31-2021 10:26
1) If you mean by pressing side button, maybe you are holding button press too long. It just takes a quick press. If you hold it longer, it activates the 'left button shortcut' which you can set from 'Settings' > 'Left Button'. I'm guessing your shortcut is set to 'Alexa'.
2) Screen should normally wake with wrist turn unless you have that disabled. If that is not working, you might have 'Screen Wake' turned off or be in 'Sleep Mode', both accessible in 'Settings'.
11-30-2021 06:38
11-30-2021 06:38
Mine was doing this too. I just fixed it by holding down the button for about 10-15 seconds and it rebooted.
05-04-2022 06:49
05-04-2022 06:49
Thank you for the tip.
05-04-2022 15:38
05-04-2022 15:38
Just happened to me as well. Followed his advice and mine also rebooted
