07-25-2023
21:36
05:43
07-25-2023
21:36
05:43
My versa 2 screen is stuck on add wallet, I have tried to hold the side button and nothing changes. I also changed the clock face in my app and it did not work.
07-26-2023 05:48
07-26-2023 05:48
Hi there, @Clemcsy. Welcome to the Fitbit Community Forums. Thanks for trying to troubleshoot the issue with your Versa 2 before reaching out.
Usually that screen will appear when opening the wallet app on your watch by either tapping on it or with left button to access to the shortcuts. While it's not possible to delete the wallet app, please give a try to the following steps to reconnect your watch to your account:
Additionally, please keep in mind that you can replace the Wallet App shortcut for any other option. To do so, open the Settings app > and tap the Left Button option. The possible shortcuts vary based on your device.
07-27-2023 19:58
07-27-2023 19:58
Unfortunately, none of these suggestions work because the left side button does not change the screen. It appears the changes or updates that Fit Bit has done recently has affected a lot of peoples devices and their screen. It would be nice if Fit Bit would own up to this and replace our devices.
