08-14-2023
12:50
03:24
08-14-2023
12:50
03:24
Versa 2 screen stuck on enter your wallet can't turn off fitbit or scroll up or down
08-15-2023 03:25
08-15-2023 03:25
Hi there, @Soulboy67. Welcome to the Fitbit Community Forums. Thanks for the details provided in your post about the inconvenience with your Versa 2.
Usually that screen will appear when opening the wallet app on your watch by either tapping on it or with left button to access to the shortcuts. While it's not possible to delete the wallet app, please give a try to the following steps to reconnect your watch to your account:
Additionally, please keep in mind that you can replace the Wallet App shortcut for any other option. To do so, open the Settings app > and tap the Left Button option. The possible shortcuts vary based on your device.
Best Answer08-16-2023 23:18
08-16-2023 23:18
08-17-2023 04:19
08-17-2023 04:19
@Soulboy67 Thanks for following the tips and recommendations I've shared above.
How are you trying to do the factory reset? In this case, I do recommend performing a factory reset and do not activate Fitbit Pay afterwards as once activated it will keep popping up on your Versa 2. To better assist you, please confirm that you've tried the following method:
At this point you can set up the watch again. For instructions, see How do I set up my Fitbit device?
Take into consideration that a factory reset deletes any stored data, which includes all data that hasn't synced to your Fitbit account, your applications, alarms, etc. So, before performing the factory reset, please make sure you've synced your Versa 2.
Best Answer08-19-2023 12:27
08-19-2023 12:27
Thank you for your reply but it's now showing set up wallet and won't do anything else won't even do factory reset by following your instructions, cheers
