10-19-2020 08:09
10-19-2020 08:09
My Versa 2 has been stuck on the set up wallet screen. It will eventually go back to the home screen, but will not go to any other screen. I have tried numerous times to reset it using the back button, but nothing happens. I have tried charging it and nothing has changed. When I go on the app it does record my steps and that I went walking, but otherwise, nothing works. 😞
10-19-2020 08:31
10-19-2020 08:31
I’m so sorry you are going thru this, @LatefahRose . Please try the following and let me know if it helps:
Hopefully this will fix the situation.
10-21-2020 06:41
10-21-2020 06:41
Will this remove all of my stored information???
10-21-2020 06:45
10-21-2020 06:45
Hello again, @LatefahRose . You say your data appears in the Fitbit app. The process I’ve described will not affect that stored data. Do try syncing first to capture anything new.
10-22-2020 06:32
10-22-2020 06:32
I ended up waiting until my Versa 2 died. Then I recharged it and it seems ok now.
