02-03-2023 05:41
02-03-2023 05:41
OK this has happened twice now. I charge my watch every night. Every night when I connect it to charge it's 80%+. I put it on in the morning and start the day with a 100% charge. The battery in this thing can last about a week, so I should never have an issue with the battery going dead.
On two seperate occasions now I felt a quick vibrate from the watch in the middle of the day. I look at the screen and there's a message there that says my battery is at 3% and some functions will now be disabled.
The first time it happened I thought msybr I did something wrong, like maybe I thought it was charging every night for a week when it really wasn't. But since then I make a point to check every night when I plug it in. Ot's charging as it should and the battery is always at 100% every morning. But this 3% thing happened again. What's going on?
02-03-2023 06:09
02-03-2023 06:09
Hi @SuperGerald - there is probably internal damage possibly from moisture collecting inside causing excessive battery drain. Check inside the back sensor windows for condensation using a magnifying glass.
