06-14-2023
11:07
11:51
AndreaFitbit
06-14-2023
11:07
11:51
AndreaFitbit
My time is consistently 10 minutes ahead & my device will not sync
06-15-2023 04:31
06-15-2023 04:31
Hi there, @Bawr. Welcome to the Fitbit Community Forums. Thanks for the details provided in your post about the issue with your Versa 2.
Please keep in mind that your Fitbit device may show an incorrect time if it hasn't synced or has been unpaired from your Fitbit account. Your Fitbit device uses the time of the device you're syncing with. To make sure your watch has recently synced, go to your Fitbit account, tap the Today tab > your profile picture > your device image.
If by any chance you are running into syncing issues, see Why won't my Fitbit device sync? or if you need to relink your watch, see How do I set up my Fitbit device?
If none of the above works for your, I recommend changing your time zone to a completely different one, sync your device, put the correct time and sync again.
06-15-2023 09:40
06-15-2023 09:40
06-15-2023 09:45
06-15-2023 09:45
@Bawr You're welcome! I'll be around if you need further help.
06-15-2023 09:48
06-15-2023 09:48
