06-06-2021
19:58
05:58
06-06-2021
19:58
05:58
Versa 2 is an hour ahead. Ive turned it off and back on and it is synced. How do i fix it?
06-07-2021 05:59 - edited 08-29-2023 10:38
Hi there, @KelJ. Thanks for stopping by in the Community Forums and troubleshooting your Versa 2 before reaching out.
Note that the time on your Fitbit Versa 2 may be wrong after you travel to a different time zone or when clocks change for Daylight Savings. If you changed time zones and the time on your Versa 2 is still incorrect after syncing, make sure the time zone setting is correct. For more information, see How do I fix the time on my Fitbit device?
Best Answer06-07-2021 05:59 - edited 08-29-2023 10:38
