08-12-2024 00:16
08-12-2024 00:16
Is running 2 mins behind my connected android phone oneplus nord. Have uninstalled the app, restarted the watch everything but still time isn't synchronised.
08-12-2024 13:32
08-12-2024 13:32
Welcome to the community forums @vinikaul.
Thank you for sharing the query regarding this inconvenience with your Versa 2. Thank you for trying to fix it on your own through the troubleshooting steps performed.
Please keep in mind that your Fitbit device may show an incorrect time if it hasn't synced or has been unpaired from your Fitbit account. Your Fitbit device uses the time of the device you're syncing with. Since you've recently restarted it, maybe your Versa 2 just needs to sync to update the time.
If you've tried the above but to no avail, make sure you're not running into syncing issues. For more information, see Why won't my Fitbit device sync?
If the issue is still not solved, but you can confirm that your Versa 2 is syncing, I recommend changing your time zone to a completely different one, sync your device, put the correct time and sync again. Here is more information: How do I change the time on my Fitbit device?
