12-06-2019
00:07
06:14
JuanJoFitbit
12-06-2019
00:07
06:14
JuanJoFitbit
Hi
Touch screen started working intermittently on my versa 2. The side button is the same.
Since the firmware update this morning, touch screen is not working at all (which probably confirms it's a software issue rather than hardware).
How do I do a factory reset without using the screen??
Thanks
12-07-2019 06:14
12-07-2019 06:14
@Tomtomato, it's great to see you in our Fitbit Community. I'm happy to assist you with your Fitbit Versa 2 since the touch screen and button are not working properly.
Regarding your inquiry, I'd like you to try a regular restart. To do so, please follow the steps that are listed in this help article. After this, try changing the clock face to one developed by Fitbit, not a third party clock face and see if the issue gets fixed.
Keep me posted on the outcome.
Best Answer07-09-2020 00:33
07-09-2020 00:33
I am also having this issue and when I do the regular restart it does work but eventually goes back to not working and i have only kept it the default clockface that comes with it.
Best Answer08-28-2020 10:26
08-28-2020 10:26
I am having the same problem. Very frustrating.
I’ve completed the reset and changed clock face back to original Fitbit face and this did not make any improvement.
Please let me know what to try next. The watch is less than 1 year old. Thank you.
Best Answer08-28-2020 13:04
08-28-2020 13:04
My touch screen has worked intermittently since April, and I only bought it last December (between December and April it was great). Not only am I not able to start its log of an exercise when I want to, but I use it as my alarm and I'm unable to turn it off in the mornings. I switched the clockface to a Fitbit made one (even deleted the other ones from the five saved) and have restarted many times.
Best Answer08-28-2020 13:20
08-28-2020 13:20
I have also experienced the same issues with my versa 2. The side button intermittently doesn’t work (more often than not), and the touch screen also does not work. I have tried restarting the watch and changing the clock faces both without success. For having just purchased this watch in December and for the price I paid I am extremely disappointed.
Best Answer09-09-2020 13:19
09-09-2020 13:19
I am having same problem recently and have tried suggestions. Nothing has improved problem. Problem is intermittent but worst at edges of screen, so ending workouts almost never happening anymore without a restart.
what do you suggest?
