07-04-2022
00:00
06:18
07-04-2022
00:00
06:18
On two occasions in the last week step count has suddenly jumped, the first time I was charging my fitbit and 65k steps were added and today, 15k steps appeared at between midnight and 00:15, whilst I was asleep.
Has anyone else seen this or know how to fix it?
07-04-2022 02:25
07-04-2022 02:25
I had the same today. Woke up to 6,500 steps. Looked online for a way to fix it but can't find one.
Best Answer07-04-2022 06:21 - edited 11-16-2023 04:17
Hi there, @Honey-badger @Sophiecc44. Welcome to the Community Forums. Thanks for the details provided in your post about the issue with your Versa 2 devices. I understand where your concern is coming from.
I'm wondering if you're using another app connected to your Fitbit account that will add more steps? Mobiletrack maybe? Low-power step sensors inside your phone track your steps and send the data to the Fitbit app. We recommend using MobileTrack if you forget your Fitbit device at home.
Note that adding more than one Fitbit device to your account gives you the convenience of switching between devices while still seeing a holistic view of your daily activity on your dashboard.
Fitbit devices have a finely-tuned algorithm for step counting. The algorithm is designed to look for intensity and motion patterns that are most indicative of people walking and running. When working at a desk, cooking, or performing other activities with arm movements, a device on your wrist may add some steps. When you’re doing activities that involve arm movement—such as working or cooking—you often walk a few steps in-between stationary periods as well, so the device tries to give you credit for those steps. For most customers, the number of extra steps added by arm-based movement isn’t significant when compared to your overall stats. For more information, see How does my Fitbit device calculate my daily activity?
For additional information, see Does the wrist I wear my device on affect the accuracy? and What can I do if my step count seems inaccurate?
If you want to negate the extra steps, see How do I add, edit, or delete Fitbit data and activities?
Hope that helps.
Best Answer07-04-2022 06:43
07-04-2022 06:43
Hi @MarreFitbit
Thank you for your reply.
I only have myfitnesspal and Strava connected, but as I don't use these I will disconnect them and hopefully the issue won't occur in the future.
Thank you for you help.
