02-03-2021 19:29 - last edited on 02-04-2021 03:17 by MarreFitbit
I am using fitbit versa 2 for a while now, recently I have noticed that when riding motorcycle also step count changes so, I want to know whether this is common or I only received defective product...??
02-04-2021 03:24 - edited 08-18-2023 04:04
Hi there @MPankaj, welcome to the Community Forums.
Please note wrist Fitbit devices count steps depending on the movement of your arms. Fitbit has worked hard to make sure that our devices do not pick up false steps or activity recordings while driving. Also, if you place it in a surface with something vibrating or if you make hard hand movements. You can learn more about how your Fitbit tracks steps by checking the article: How accurate are Fitbit devices?
As @Odyssey13 has already recommended you, if you want to remove the steps from your daily total, manually log the driving activity for the time you were in a motorcycle. For more information, see How do I add, edit, or delete Fitbit data and activities?
02-03-2021 19:35
02-03-2021 19:35
Hi @MPankaj motorcycles do seem to pick up steps, but you can remove those unwanted steps caused by riding. Go to your log and select the time period when you were on your motorcycle and enter it as driving. Those extra steps will be removed.
11-26-2022 18:17 - edited 11-26-2022 18:19
More unacceptable solutions as pushed in other fitbit device threads. Fitbit is now out of the running for my next device since others are able to avoid adding steps while riding a motorcycle.
11-26-2022 18:46
11-26-2022 18:46
Riding my motorcycle is the only way I got 36k steps and over 150 floors in one day. My versa 2 is in a constant boot loop now so that won't be happening any longer. Looking at a Garmin or Samsung for my next watch.
