10-11-2019 15:30
10-11-2019 15:30
I found the fix on a youtube video for when your VERSA isn't vibrating when you get text messages and phone calls.
However, I also updated the app on my watch, while i was watching the video. The fix is no longer valid as the 'press and hold' to the single left button feature, now just brings up 'quick settings' that do not feature notifications as an option (it used to).
My vibrations are working on other things, just not texts and calls. Texts are coming through if I pull down from the top, but I don't know I have one, because vibrations aren't working. My phone is set up to vibrate on notifications.
I don't know how to get to the notifications on/off option on my watch any more with this update.
There is also no 'notifications' option under the settings button either, like there used to be. Instructions on how the update works would be super helpful. I really need to turn the vibrations back on.
I am using an LG G8 ThinQ phone.
Thanks for your help, I'm a newbie to the forums.
10-11-2019 18:28
10-11-2019 18:28
Have you looked under the settings app, @Daisyflame
Best Answer04-20-2020 12:08
04-20-2020 12:08
I read elsewhere that you should hold the left button 10-seconds and let it restart. If that doesn't fix it then do it again. I did it twice and that didn't help. This time I went to my phone and in the Fitbit app I went to settings. Once I was there, a message popped up about bluetooth so I connected. Then a second message popped up asking if I wanted alerts and I accepted that too. Now the Versa 2 displays who is calling and vibrates as it should.
