Versa 2 update changed active minutes to zone minutes
I updated my Versa 2 last week and I’m now realizing that the reason my minutes weren’t syncing is because the app suddenly went from active minutes to zone minutes. I average about 13.5k steps a day, this is so frustrating. Is there any way to fix it?
3 REPLIES 3
Hi @mlofberg87 - in the later firmwares they changed it from active minutes to AZM.
Unfortunately you can't go back.
I use SimpleClockPro and that is able to show both but the Fitbit app only shows AZM.
That’s so aggravating. This has happened before, but when I got a new one it went back to active minutes. Lesson learned: don’t update.
@mlofberg87 - yes, if you can stick with the original factory reset firmware (generally not always possible) you will have the older active minutes.
But there may be other newer things that won't work or more recent clock faces you can't install.
There may be Fitbit app incompatibilities also.
