11-04-2019 12:59
11-04-2019 12:59
Hi...I just bought the fitbit versa 2 🙂 anyway I've tried SEVERAL times to respond to texts using voice in the car and it won't work. Even with the radio off. Has this happened to anyone else? It works every where else unless noisy ofc. Thanks
11-05-2019 01:21
11-05-2019 01:21
Are you speaking through the Versa 2 or a Bluetooth device?
Do you have a good Internet connection?
Any error messages
When saying it doesn't work.. It is usually helpful to 'em lids in what way it don't work?
Best Answer11-05-2019 01:26
11-05-2019 01:26
Hi Rich,
Good point thank you. Im n actually b speaking through the versa... it just has three blue lines moving up and down like it does when processing and it continues for a while and then In her a blue circle and it will say can't recognize try again?
Best Answer11-05-2019 08:20
11-05-2019 08:20
How noisy is your ride?
Best Answer11-05-2019 08:36
11-05-2019 08:36
I didn't think that loud?! I have a Honda Odyssey. I drive on the highway but I turn the radio off to talk. It must be loud though because even my Alexa wasn't working great
Best Answer11-05-2019 10:54
11-05-2019 10:54
I'm just taking guesses.
It issounds like the voice is not getting through or a spotty Internet.
