01-23-2020 06:15
01-23-2020 06:15
Fewer calories credited by 2 than one for same workout. No difference in calories if entered manually for distances as great as .4 miles. Huge difference between 2 and 2.1 miles if entered manually. Versa two usually does not get distance correct. Versa usually did.
01-30-2020
20:23
08:48
01-30-2020
20:23
08:48
@Elanhui It's nice to see you around. Sorry for the delayed reply.
I appreciate the details mentioned. In this case, I would like you to confirm that you have properly set your pool length on your Versa 2. Also, please provide me with a screenshot of the data that you were receiving with your Versa 2 and the data you're receiving with your Versa.
Keep me posted. I'll be around if you have any additional questions.
Best Answer02-03-2020 15:20 - last edited on 02-09-2020 16:02 by LiliyaFitbit
I will try to attach two screenshots of identical workouts. One is with the Versa and the other is with the Versa 2. I had to correct the second this morning as it only credited me for 1.1 miles. I usually have to do this with the Versa 2 because it usually under calculates the distance swam. You can see that the Versa estimated a higher number of calories than the Versa 2.
I swim a little over two miles on the weekend. This is 72 laps on both occasions. The intensity is varied but the stoke is the same throughout the workout. I don’t make flip turns but they are good for an amateur who has swum over 12,000 in her 59 years. They last just long enough for me to glance at the Fitbit to see my time.
Thank you for your help.
Sincerely,
Sent from my
11:28
08:48
02-05-2020
11:28
08:48
@Elanhui Thanks for getting back. I appreciate the details mentioned.
Please make sure that both of your watches have the correct information entered and that you have them set up in different accounts. If you have a screenshot of the data, please attach it to your next reply.
Best Answer02-05-2020 13:46
02-05-2020 13:46
Best Answer02-05-2020 13:51
02-05-2020 13:51
I thought I successfully attached two screenshots. Two identical workouts but one was from the Versa back when I still used it and the other was from the Versa II. As you can see, the Versa II awarded my more calories for the same distance and roughly the same amount of time. The info is entered correctly. My weight has not change by more than a pound and the pool is still 25 yards.
17:17
08:47
02-06-2020
17:17
08:47
In this case, I would like you to restart your Versa 2 and try wearing your watch on your other wrist, keep in mind that you need to change your settings on your account too.
Keep me posted.
Best Answer02-07-2020 04:35
02-07-2020 04:35
15:36
08:47
02-08-2020
15:36
08:47
@Elanhui Thank you for getting back. In this case, I've shared your post with our Support team and they will continue assisting you through email, please check your inbox.
Best Answer02-08-2020 16:27
