Versa 2 wake screen doesn't swipe, at times it does not turn on
I have recently encountered such issues where the wake screen by gestures display the time but doesn't do anything else when swiped. I proceed to allow the watch to turn off by gesture and it doesn't turn back on at all when i again rotate and held up my wrist, plus the button on the side of watch did not turn the watch on when this happened and i will get a blank screen for a long time before i put it down and let it rest then it works again.
3 REPLIES 3
Hi @Aquaman83 That doesnt sound normal. Try restarting it several times and see if that fixes it. If it doesnt then try a Factory Reset and set the tracker up again. If it still co tinues to cause problems then contact Customer Support
Restart your tracker
Fitbit Support
BUTTON FACTORY RESET FOR VERSA 2 AND VERSA LITE
Hold the back button for about 8 seconds.
When the Fitbit logo disappears: Release the button briefly (for less than 2 seconds).
Hold the button again until you feel a second, longer vibration, which indicates the factory reset.
Community Council Member
Helen | Western Australia
I try restarting the watch and it works for a while before decided to play up on me again. I also feel a small vibration from time to time and the heart rate will revert to no numbers when this happened.
There must be something wrong.
Try the factory reset but if that doesnt cure the problem then please contact Support
