09-17-2019 12:39
09-17-2019 12:39
Hello, I have the original Versa and am not ready to upgrade just yet (everything works fine) but I really like the watchface on Versa 2 that is being shown on all adverts with it. Can this watchface be applied to old Versas? If so, anyone know what's the name of the watchface so I can find it? Thanks.
09-17-2019 12:45
09-17-2019 12:45
Hi @VandaJL.
The two clock faces I've seen in promotional material are waveform and sundial. They are not available on older device.
09-17-2019 12:45
09-17-2019 12:45
Hi @VandaJL.
09-17-2019 12:49
09-17-2019 12:49
Awww, that's too bad. Thanks for the quick response though.
12-21-2019 15:30
12-21-2019 15:30
Waveform Vectors is close to.the Waveform watchface. I like it and am using it.
12-23-2019 00:08
12-23-2019 00:08
,brett - I love it, thanks!
02-17-2020 20:50
02-17-2020 20:50
Can you tell me how you edited the colors? I can only get black and yellow which is default. Unless the creator hid the settings. Thanks.
02-18-2020 22:25
02-18-2020 22:25
and I want to change the clock format to 24-hour. How to do that?
