03-11-2021 14:43
03-11-2021 14:43
I have been logging water consumption on my Versa 2.
It is working well and syncs to FitBit dashboard.
How do I see the total amount of water I have drank today?
Most of the time the display only shows my last logged entry.
Sometimes I can see the total water so far today.
Is there someway I can make it display total for today?
03-14-2021 17:10 - edited 03-21-2021 18:51
Thank you for visiting the Fitbit Community @RichardMW.
Thanks for the information provided.
Please swipe up from the clock face on your Fitbit Versa 2 to access Fitbit Today which should show up your stats. Please scroll down until you find the water logged widget, if you don't see it please go to the bottom of the screen, tap Settings and add it.
Now you should be able to see water intake logged today and history over the past 7 days. Please swipe left or right on the water tile to view the complete set of stats.
Hope this helps.
03-14-2021 18:27
03-14-2021 18:27
Edson,
I already knew how to do this and how to log water consumption.
The problem is that after adding 8 oz water the Versa 2 only shows that 8 oz was added at 1 PM.
After a few hours, it will show the total for the day so far.
I want to be able to switch between the recent entry and then show the total so far today.
03-21-2021 18:55
03-21-2021 18:55
Thanks for your response, @RichardMW.
In this case, you are welcome to make a suggestion in the Feature Suggestions board which is constantly monitored by our engineering team for future implementations. Once any update be available, it will be communicated as soon as possible.
See you around.
