12-16-2020 20:31
12-16-2020 20:31
My versa 2 will not light up after 10:00 p.m. with movement of my arm. How do you fix it to come on with movement of your arm after 10? It will come on if you double tap the screen or press the button.
12-17-2020 09:14
12-17-2020 09:14
It sounds like you have Sleep Mode activated to automatically come on at 10 PM. Preventing screen from lighting with wrist turn is one of the things Sleep Mode does to not disturb you while asleep. You can find Sleep Mode in 'Settings' and turn it completely off or adjust the hours for it.
