01-18-2020 12:42
01-18-2020 12:42
It looks like there are others having this problem. I have a Samsung Galaxy S10e. The watch was replaced under warranty once but the new watch is having the same problem: unable to receive text messages but calls and other notifications come through fine. I have done all recommended troubleshooting including a factory reset. I'm starting this string to determine if anyone has been successful in fixing this problem?
01-18-2020 12:49 - edited 01-18-2020 12:54
Hi @kemac , it's obvious meanwhile that this is caused by the newest Firmware update 70.7.14 and, for unknown reason, mainly affecting Samsung owners. Fitbit is aware of it and working on a fix. When released? I do not know a timeframe. Regards kuzibri
01-18-2020 12:53
01-18-2020 12:53
Haven't been able to receive them on my iPhone for quite a while. keep being told they are working on it. Time to consider getting a different tracker
01-18-2020 12:55
01-18-2020 12:55
Hi @bcandy , this problem is caused by the iOS 13 update which is something totally different. Regards kuzibri
01-21-2020 08:46
01-21-2020 08:46
Putting this out there because I think others are having the problem. I went through all recommended troubleshooting without success. Yesterday I finally installed Google messenger (I was using the default messenger app from Samsung). Don't forget to set Google as the default messenger app in Fitbit. At least for the last 24 hours or so I've been receiving text messages on the Versa 2!! Cross fingers that it continues to work!
01-21-2020 09:02
01-21-2020 09:02
HI @kemac I use Messenger+ and it works well. Glad you didn't give up!
01-21-2020 10:05
01-21-2020 10:05
Fought with my Versa 2 for a week trying to get texts to come through. I have a Note 10 plus. After much research, I was told by Samsung that they included an update to their Message app with the Android 10 update. That update possibly broke the text notifications. While I do prefer the stock Samsung app, installing Google Messages and making it the default messaging app fixes the issue.
01-24-2020 16:51
01-24-2020 16:51
I just now installed Google Messages and set as my default text app. Finally receiving texts now on my Versa after updating my Note 10 plus!
01-24-2020 17:11
01-24-2020 17:11
Can you explain how to make google my default?
01-24-2020 20:01
01-24-2020 20:01
02-11-2020 14:21
02-11-2020 14:21
You're lucky, I don't get anything except a random notification that I've missed a call. I checked to see if the Versa 2 was compatible to the S10e and the website said it was...that didn't work out well. Please hurry up with the updates needed to get this working properly!
