05-23-2020
12:48
11:35
DavideFitbit
05-23-2020
12:48
11:35
DavideFitbit
Had the Versa sometime and now the unit will not show the heartbeat and flame thing. It is stuck on the steps. I can not swipe across to get to any of the settings on the watch like the exercise, music and etc. It is stuck on the face of the clock only. When I reboot it, it does work for a short amount of time, but then gets stuck again. This started when the watch went to my exercise app for riding a bike. It got stuck on that and I could not stop the time from just adding up. Finally had to reboot the watch to make it stop. It totally took down the battery running up the time like it did. Like I said now it works for awhile, but then gets stuck again on the watch face and won't swipe to anything. Still get notifications. Any help would be appreciated.
05-23-2020 13:02
05-23-2020 13:02
Hi @sunnygin , if you are using a third party clock face, change it to one developed by Fitbit itself and restart your Versa. If you're using a Fitbit CF, restart your Versa 3-4 times in a row untill you see each time the Fitbit logo (internal reset) and see if that solves your problem. Otherwise, contact Customer Support. Erik
05-23-2020 15:16
05-23-2020 15:16
05-27-2020 11:13
05-27-2020 11:13
As luck would have it, Fitfit did an update on the Versa 2 and that seemed to solve my problems. Watch is working fine again.
