03-24-2020 15:08
03-24-2020 15:08
Yes I have tried all the suggestions provided.
restart phone, restart watch, turn of phone Bluetooth, make sure no other Bluetooth is around (I went into the bushes), reset watch (even worse because now I cannot even use the watch anymore).
I noticed that my sleep was not being tracked so I went to the app. My versa 2 no longer showed up in the DEVICE section. I tried to add it back and I get to the point with it ask for the 4 digit pin. I punch in the pin and after a minute i get "Not working?" message.
I have been trying since Sunday. This is not a singular issue because I bought my girlfriend a Versa 2 as well. I asked her to look at her app and see if her watch was connected, It was not.
I asked her to try and add it, she got the same message over and over again "Not Working?"
It is not possible that our watches went bad at the same time. This seems like a software issue because they updated it last friday.
03-24-2020 15:41
03-24-2020 15:41
I don't see the Phone model @towch?
You say she tried to add, did she try to add your tracker to your account through her phone? Does she have a different phone?
03-24-2020 15:55
03-24-2020 15:55
She tried to add her tracker back to her account. She discovered that her tracker also was not connected to her app anymore, just like mine.
I have a pixel 3XL
She has a pixel 2XL
I just tried using my old LG G6 to add my tracker, same problem and error message.
03-24-2020 17:24
03-24-2020 17:24
I have a versa and also have the same problem starting Sunday morning.
03-26-2020 12:18
03-26-2020 12:18
@Gr8w8 any success or update on your end?
03-28-2020 07:58
03-28-2020 07:58
03-28-2020 10:45
03-28-2020 10:45
My Versa stopped syncing on 18 March. Now it won't connect to the App at all. Like you I get to put in the 4 code pin for set up amd then its says not working.
Beginning to think there is a fault in the App but with Covid 19 the chances of getting Fibit to correct it are pretty slim.
03-28-2020 12:02
03-28-2020 12:02
I can sync with the Windows 10 app, but not with the phone app.
03-28-2020 16:04
03-28-2020 16:04
People really need to stop removing a non syncing tracker from their Fitbit accounts. Doing so will simply add more problems.
03-28-2020 19:39
03-28-2020 19:39
What do we do then if it's still a problem? I tried everything too! So frustrated right now!!!
