Versa 2 won't charge anymore
I have cleaned bother charger and fitbit and 'not enough power from source ' is still appearing and fitbit is not charging. I have tried different leads and charger.
2 REPLIES 2
Hi @Denbane - did you try using the PC as the power source.
Also sync then Shutdown the watch from the Settings menu and charge for 2 hours making sure it doesn't get hot, in case there is a watch fault.
It may come on by itself or you may need to restart it by pressing the button a few seconds.
Hi there, @Denbane. Welcome to the Fitbit Community Forums. Thanks for trying to troubleshoot the charging issues with your Versa 2 before reaching out. We'll be glad to help you with this!
I agree with @Guy_'s advice as sometimes a Fitbit doesn’t seem to be charging when actually the issue is that it has become unresponsive (this can happen if the battery has been allowed to discharge completely). So, I too recommend leaving your Versa 2 on the charger for a good two hours, even if it doesn’t seem to be charging.
When it has had two hours, try restarting your Versa 2. I would recommend trying this maybe twice in a row if a first try doesn’t work.
Regarding the power source,
please find below some tips to best charge Fitbit devices:
  • Use only genuine Fitbit charging cables
  • Use only UL-certified wall chargers
  • Avoid USB battery packs
  • Charge at room temperature
For charging purposes, your charging cable or your base station can be plugged into any USB power source, including but not limited to:
  • A computer
  • A Wall A/C to USB adapter, commonly found with smartphones
  • A DC to USB adapter (vehicle power port)
