02-05-2024
		18:33
		03:23
		02-05-2024
		18:33
		03:23
My Versa 2 will not charge. It is barely year old. I've tried two different chargers and multiple USB ports. How do I fix this?
02-05-2024 23:20
02-05-2024 23:20
Have You tried a charging block rather than a port. are U using the charging cord included specifically for your versa 2? I use a charging block that came with my tablet, the output is higher than a computer port. Good luck
02-06-2024 03:26
                                          Community Moderators ensure that conversations are friendly, factual, and on-topic. We're here to answer questions, escalate bugs, and make sure your voice is heard by the larger Fitbit team.  Learn more
                              02-06-2024 03:26
Hi there, @Jmrand0101. Welcome to the Fitbit Community Forums. I'm sorry to hear that your Versa 2 is still not charging despite the steps you've tried so far. I understand where your concern is coming from as it's not that old. We're to help!
Have you tried what @Ecomshopper has suggested to you?
On a side note, please note that sometimes a Fitbit doesn’t seem to be charging when actually the issue is that it has become unresponsive (this can happen if the battery has been allowed to discharge completely, like in your case). I'd recommend putting it on to charge on a charging wire and outlet known to be working.  Leave it on the charger for a good two hours, even if it doesn’t seem to be charging.
When it has had two hours, try restarting your Versa 2. I would recommend trying this maybe twice in a row if a first try doesn’t work.
Was my post helpful? Give it a thumbs up to show your appreciation!  Of course, if this was the answer you were looking for, don't forget to make it the Best Answer! Als...
 Best Answer02-06-2024 18:12
02-06-2024 18:12
