Versa 2 won't charge or turn on
ANSWERED
My Fitbit versa 2 won’t charge or turn on
1 BEST ANSWER
Accepted Solutions
Hi there, @Jlbjade @joyspikey. Welcome to the Community Forums. Thanks for the details provided in your post about the issue with your Versa 2 devices.
As a first approach, I'd recommend restarting your Versa 2. For instructions, see How do I restart my Fitbit device?
If the restart doesn't work and your Versa 2 does not vibrate while trying to perform the restart, I'd suggest trying the below steps:
  • Clean the charging contacts on the back of your device and the pins on your charging cable using the instructions in How do I clean my Fitbit device?
  • If the error "insufficient power source" appears on your device's screen, remove other devices plugged in to your power source, or plug your device in to another source.
  • Try a different USB port or a UL-certified wall charger.
  • Check the alignment and try reconnecting your device to the charging cable. For more information, see How do I charge my Fitbit device?
  • Restart your Fitbit once again. For more information, see How do I restart my Fitbit device?
If the above steps don't work, I'd suggest performing a restart by following the steps below (please remove your Versa 2 from your phone's Bluetooth before performing this step):
  1. Hold the back button for about 8 seconds.
  2. When the Fitbit logo disappears:
    1. Release the button briefly (for less than 2 seconds).
    2. Hold the button again until you feel a second, longer vibration, which indicates you initiated the factory reset.
You can follow the steps to set up the device after that: How do I set up my Fitbit device?
Take into consideration that a factory reset deletes any stored data, which includes all data that hasn't synced to your Fitbit account and your applications, alarms, etc.
@joyspikey Regarding to your inquiry, you can buy Fitbit accessories at https://www.fitbit.com/global/us/products
Hope that helps.
4 REPLIES 4
where can we buy the charger??
in singapore
Hope that helps.
Thank you for this ,
sadly none of the above are working ?
what is my next step ?
@Jlbjade I appreciate you had followed the tips and recommendations provided above.
At this moment, I’ve reached the limits of what I can do for you here on the public community forums. The best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
