11-25-2022
04:00
15:24
11-25-2022
04:00
15:24
My versa 2 stopped fully charging. At first only charged to 98% now will only charge to 96% how do I get it to charge to 100%
11-27-2022 04:41
11-27-2022 04:41
Hi @Diggydiana1956 - your post has been moved to the correct forum.
There are a few things to try.
Perform a Shutdown from the watch Settings, About menu. Wait 10 at least seconds before placing on the charger to restart it and charge it.
If this doesn't help try letting it run down completely and charge it fully a few times. Sometimes patience is required and it takes an hour or more to charge the last few percent.
However it probably is a waste of time charging it fully because that can be an hour or more you are not wearing it and the duration between charges is not significantly prolonged.
Best Answer11-28-2022 15:25 - edited 07-24-2023 08:10
Hi there, @Diggydiana1956. Welcome to the Community Forums. Thanks for the details provided in your psot about the issue with your Versa 2. @Guy_ Thank you so much for your help!
I've seen you contacted our Support Team after posting here and they've already assisted you. If you still need help or have any questions/concerns regarding the outcome of your case, please feel free to contact our team back for further assistance.
