07-17-2025 22:18 - edited 07-18-2025 17:22
After I factory reset my Versa 2, the screen shows `download Fitbit App`, then it stays there, nothing can be done.
When I open Fitbit App on my iPhone, try to add a new device, follow the instructions to charge the tracker, and search... it is always showing `Not found`.
Tried a lots of ways, turn on/off bluetooth, restart iPhone, restart Versa 2, no luck.
Now my Versa 2 becomes a brick, so frustrating
07-18-2025 09:38
07-18-2025 09:38
Hi there, @chaoyangnz. Welcome to the Fitbit Community Forums. Thanks for bringing this to my attention and for the troubleshooting steps you've tried. I'm sorry to hear that your Versa 2 is not connecting after a factory reset. I understand your concern and how you must be feeling, I will do my best to help you with this!
In addition to the steps you've tried, I'd recommend trying the following in the order listed:
If you can't get started with your Versa 2, usually a missing requirement is the cause. Carefully review the requirements provided in the help article: Why can't I set up my Fitbit device?
07-18-2025 17:21
07-18-2025 17:21
Thanks, after I tried the steps a few times, now I succeeded to connect Fitbit App.
Best Answer07-19-2025 06:16
07-19-2025 06:16
@chaoyangnz Awesome! I'm glad to hear that you're back on track.
I would like to invite you to visit our Health & Wellness where you will find great tips and encouragement from other members.
Happy stepping!
