07-02-2020
14:33
08:53
07-02-2020
14:33
08:53
Hi, I'm have trouble with my Versa 2 connecting to my Amazon echo buds for bluetooth headphones. It gets the the pairing echo buds screen and keeps spinning. Any suggestions?
07-03-2020 11:26 - edited 07-03-2020 11:27
Hi there @Kanb, welcome on board. I appreciate your participation in the Forums and for sharing your experience with us.
I'd recommend you to remove all Bluetooth devices in your Versa 2. Then, restart the Versa 2 by following these steps: How do I restart my Fitbit device?
After that, restart your wireless buds following the instructions from the manufacturer. Then, pair the buds again and let me know if you're still experiencing the same situation so I can check this further.
In addition, make sure to take a look at this article to properly pair your Amazon echo buds: How do I connect Bluetooth audio devices to my Fitbit watch?
Keep me posted on the outcome, I'll be around.
07-03-2020 11:35
07-03-2020 11:35
I have no other device connected via bluetooth to my versa2. I have also reset my echo buds.
07-27-2020 21:09
07-27-2020 21:09
Hello,
I am having the exact same problem. It just spins and spins. I have restarted numerous times & nothing has changed.
07-28-2020 03:54
07-28-2020 03:54
Yeah, I've just about given up.
10-20-2020 11:29
10-20-2020 11:29
I was able to successfully pair my Echo Buds with my Versa 2.
The trick is, AFTER you open the case and press the Echo Buds pair button you have to remove both Echo Buds from the case and place them in your ears, you should hear "Now in Pairing Mode"
THEN you select the Echo Buds on your Versa 2 to complete pairing.
Failing to place Echo Buds in your ears causes the spinning pairing status referred to above.
08-14-2021 12:40
08-14-2021 12:40
I used this link on Amazon. It's more about how you use your Echo Buds than just using the watch.
Hope it works for you. Tried for 3 days, then found this link, worked after follow the instructions.
Good luck.
