07-04-2022
14:11
09:20
07-04-2022
14:11
09:20
I have shut down my iphone 11 and restarted. Cannot connect the bluetooth to the iphone 11. It was working and synced this morning. All are fully charged. The Versa 2 had frozen logo screen. I reset many times. Nothing. Still frozen screen and will not connect to the bluetooth. any ideas?
07-05-2022 09:21 - edited 07-18-2023 10:37
Hi there, @fireinthesky. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa 2 before reaching out. I understand where your concern is coming from.
In addition to the steps you've done so far, I suggest trying the following:
If you can't get started with your Versa 2, usually a missing requirement is the cause. Carefully review the requirements provided in the help article Why can't I set up my Fitbit device?
Best Answer07-05-2022 09:21 - edited 07-18-2023 10:37
