02-19-2023
04:35
07:52
02-19-2023
04:35
07:52
My iPhone can’t detect the Fitbit Versa 2. Had no problems for 2 years but now this
02-20-2023 08:27
02-20-2023 08:27
Did you update your iPhone to the latest iOS release? I had same prob & the iOS 16.3 update fixed my sync prob. UNFORTUNATELY, after subsequently installing the latest Fitbit App release (3.75) I now have a diff sync prob. Every single time I try to sync, I have to forget my Versa in BT then re-pair it.
Don’t know what’s worse; lack of adequate testing or release mgr giving the ok to go live w/it. And they never specify in the release notes what ‘bug fixes’ they’re promoting. The whole point of release notes is to tell users WHAT probs they’ve fixed.
Best Answer02-20-2023 07:54 - edited 10-18-2024 08:28
Hi there, @ElsaQ. Welcome to the Community Forums. Thanks for the details provided in your post about the issue with your Versa 2.
If you haven't done so yet, I suggest trying the following steps:
Best Answer02-20-2023 08:27
02-20-2023 08:27
Best Answer02-21-2023 11:33
02-21-2023 11:33
02-21-2023 11:33
