08-01-2021
06:58
07:06
08-01-2021
06:58
07:06
08-06-2021 07:11 - edited 11-01-2023 18:02
Hi there, @soulslayer. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa before reaching out. We‘re taking into consideration your comments and sentiments in regards to our products and Customer Service. @L.E. Thanks for trying to help!
May I know the model of your mobile phone? Please make sure it meets the requirements listed here.
Despite meeting the above requirements, the following devices often exhibit compatibility issues that cause our products and services to not operate properly:
If your phone is not on the list above and meets the requirements to operate properly with the Fitbit app, please try the steps below:
1. Remove the Versa from your phone's Bluetooth settings and in the Fitbit app.
2. Restart your Versa.
3. Turn off other Bluetooth connections when not in use.
4. Plug it into the charging cable and open the Fitbit app.
5. Set up your Versa.
If you continue having issues while updating your watch, please see Why can't I update my Fitbit device?
Hope that helps.
08-01-2021 08:20
08-01-2021 08:20
Is your Versa working now?
Hope that helps.
