07-10-2023
06:22
06:48
07-10-2023
06:22
06:48
I thought I was dead when my data didn’t go through when I restarted my versa watch! YouTube and Fitbit support was useless! I turned off the Bluetooth and I tried to reconnect my watch and sync it! But it doesn’t seem to work! I tried turning it on and off, restarting it multiple times, but it won’t work! Help me please!!
07-10-2023 06:51
07-10-2023 06:51
Hi there, @Jamiberries. Welcome to the Fitbit Community Forums. Thanks for trying to troubleshoot the issue with your Versa 2 before reaching out. We‘re taking your comments and sentiments in regards to our products and services into consideration.
In addition to the steps you've done so far, please try the following:
With the steps above, what I want you to do is to pair your Versa 2 first to your phone's Bluetooth settings before any other Bluetooth device is connected to your phone.
07-10-2023 06:51
07-10-2023 06:51
07-10-2023 12:30
07-10-2023 12:30
Same here! Just over 5 hours ago. Had full battery, recorded my sleep, i saw my data in the app this am…then my mom messaged me her Fitbit just randomly died and she was getting a replacement.. I thought geez that sucks- then I looked at mine and it’s just been the logo flashing on the screen! I’ve tried every single thing recommend to try to fix it. Something is going on. Hope someone can answer this!
07-10-2023 12:43
07-10-2023 12:43
I just saw a YouTube video that said to keep pumping the side button quickly on and off until the logo stays on… then wait a little! It worked for me after trying all the different things Fitbit support told me to do (but none of them worked)
hope this can help someone with versa 2 issues!
It’s syncing with my iPhone now and working properly again.
07-10-2023 17:27
07-10-2023 17:27
I’ve tried that but it will only intermittently connect to the Bluetooth and then will disconnect. It won’t sync at all now. I’ve factory reset it about a dozen times and it’s worthless at this point.
07-11-2023 07:05
07-11-2023 07:05
Same here, plus I just drive to a new time zone area for a holiday and it won’t update the time
07-11-2023 07:06
07-11-2023 07:06
Done all that. Still stuck
07-13-2023 19:23
07-13-2023 19:23
Are you using an iPhone & if so, what iOS version? I had constant BT probs (only w/my Versa) after installing ios 16.5 & the only way to sync it was to forget the device in BT & Re-pair every single time. The prob magically went away after I installed the iOS 16.5.1 update.
07-14-2023 03:04
07-14-2023 03:04
I'm up to date with 16.5.1 and have been. I had already updated before the problem began. Glad your problem resolved. This was the last straw for me with Fitbit.
