08-17-2023
03:27
04:46
08-17-2023
03:27
04:46
My versa 2, died during the night. (Was on 50% going to bed) I have fully charged it, and realised that the t8me is incorrect. Have uninstalled both the versa and the app, and it is still not connecting to my phone
08-17-2023 04:50 - edited 08-17-2023 04:50
Hi there, @Eilmc. Welcome to the Fitbit Community Forums. Thanks for trying to troubleshoot the issue with your Versa 2 before reaching out.
In addition to the steps you've done, please try the following in the order listed:
With the steps above, what I want you to do is to pair your Versa 2 first to your phone's Bluetooth settings before any other Bluetooth device is connected to your phone.
Once you manage to sync your Versa 2, the time should be corrected. Keep in mind that your Fitbit device uses the time of the device you're syncing with.
08-17-2023 05:05
08-17-2023 05:05
Thank you. Unfortunately this is not working, I'm getting a message stating 'data not cleared, sync and try again'. I can't sync it as it is no longer connected 😢
08-17-2023 05:24
08-17-2023 05:24
@Eilmc Thanks for getting back and the details provided.
Please note the message "Data not cleared, Sync & Try again" usually appears when you performed a factory reset without first unpairing your watch from your phone's Bluetooth settings.
Nevertheless, the steps I've provided above should work for this scenario too. Are you getting stuck at any step?
In the meantime, please try restarting your Versa 2 and then, try all those steps again in the order listed.
08-17-2023 05:37
08-17-2023 05:37
Hi there, I have tried to restart it again, and am getting the data not cleared message all the time now. So yes I am stuck.
Thanks
