12-08-2022
05:40
12:33
12-08-2022
05:40
12:33
I have tried every troubleshooting step, on multiple devices and I still cannot get my Versa 2 to connect to Bluetooth.
I have restarted my phones multiple times. I have restarted the watch multiple times. I have uninstalled and reinstalled the app on both devices multiple times. I turned the bluetooth off on one device if I was trying the other. I have turned bluetooth on and off several times. I have allowed all permissions.
I cannot get it to move past the Bluetooth pairing and linking page and it either just sits there circling or it gives an error and every time I try again it doesn't do anything. What do I do?
12-16-2022 12:39 - edited 03-09-2024 07:46
Hi there, @Andjordan. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa 2 before reaching out.
As a first approach, I'd like to confirm if you're trying to use two mobile devices to set up/sync your Fitbit device? If so, please note that you can use both devices. However, if you haven't set up your Versa 2 yet, try setting it up with one of the two devices while the other remains with the Bluetooth turned off or better yet, try turning off your mobile device.
Bear in mind that your Fitbit device can only talk to one device at a time. It can be trusted on many devices, phones, tablets, and so on, but because of the limitations of Bluetooth, it will only be able to talk to one at a time.
If the above doesn't describe your issue, please try the following:
If nothing seems to work, please follow @Guy_'s advice and chat with us online or give us a call. Click here to get connected.
Best Answer12-08-2022 05:55
12-08-2022 05:55
Hi @Andjordan - it seems you have done some good troubleshooting, but one issue could be trying multiple devices. It might be a good idea to chat via the Fitbit App, click profile photo, Help & Support, Contact Customer Support. They can guide you through the various steps in case you missed one or if necessary factory reset the watch.
If that has to be done, make a note of the names of any clock faces or apps you have downloaded and any special settings, for setting it up again afterwards.
Best Answer12-16-2022 12:39 - edited 03-09-2024 07:46
Best Answer02-18-2023 19:17
02-18-2023 19:17
I have the same issue. Although haven't tried to pair on multiple devices. It's been paired to my iPhone for most of the last year. This morning tried to have Fitbit app sync up and suddenly said it needs to pair.... wth happened. Searched online says to delete it from bluetooth in iphone and reboot iphone then reconnect. I reconnect from iphone bluetooth and it tries... and when bluetooth connects you get the information button on right that you click on that allows you to "forget device" it never gets that far now for versa 2. So rebooted again, verified doesn't show in bluetooth, started the app and it says it needs to pair. Which i say yes.... it tries and then it asks if I want to "Fix" then I "click fix" and check it on bluetooth and same issue.. never gets far enough to get the info button..'
Even weirder, some of the information Does update in fitbit but still gives the error that needs to connect... Have hard shut down several times, rebooted phone and restarted app and gone through process 3-5 times same results...
This has been working fine for at least 9 months as this is a replacement watch from one that stopped taking a charge, and now it won't connect on bluetooth suddenly.
