12-14-2021
01:22
05:34
12-14-2021
01:22
05:34
Hi guys!
my fitbit versa 2 doesn’t want to connect with bluetooth on my phone or my wifi at home eventhough they are both on and my connection is stable.
i already tried deleting the app/reinstalling it.
12-14-2021 05:36 - edited 03-14-2024 06:08
Hi there, @Sher.dina. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa 3 before reaching out.
May I know the model of your mobile phone? Please make sure it meets the requirements listed here.
Despite meeting the above requirements, the following devices often exhibit compatibility issues that cause our products and services to not operate properly:
If your phone is not on the list above and meets the requirements to operate properly with the Fitbit app, please try the steps below:
1. Remove the Versa 2 from your phone's Bluetooth settings and in the Fitbit app.
2. Restart your Versa 2.
3. Turn off other Bluetooth connections when not in use.
4. Plug it into the charging cable and open the Fitbit app.
5. Set up your Versa 2.
12-14-2021 06:46
12-14-2021 06:46
Thank you so much Maria! It helped 🙂
12-14-2021 06:52 - edited 09-01-2023 08:39
@Sher.dina Awesome! I'm glad to hear that the steps recommended did the trick. 🙂
I would like to invite you to visit our Health & Wellness where you will find great tips and encouragement from other members.
