11-09-2020
02:47
13:14
11-09-2020
02:47
13:14
My Versa 2 ran out of battery a number of weeks ago and I didn’t get around to charging it up as I was away. When I did, the watch would not sync to my phone so I removed it from the App and tried to re connect. This didn’t work. So I followed advice on here and factory re set the watch. Now I when I try and set everything up again, the phone identifies the Versa but won’t connect to it . I have tried everything. Please can someone help ASAP. Thanks, Saskia
11-09-2020 13:14 - edited 09-19-2023 05:35
Hi there @Saskiamay10, welcome to the Community Forums. I'm sorry to hear about the connectivity issues you've been having with your Versa 2, I understand where your concern is coming from and how you must be feeling. Thanks for already trying to fix the issue prior to posting here, I'll be glad to continue helping you.
Besides to the steps you already performed, I'd recommend trying the ones below:
If you can't get started with your Versa 2, usually a missing requirement is the cause. Carefully review the requirements provided in the help article: Why can't I set up my Fitbit device?
In addition, please know Fitbit products are compatible with most devices that have the following operating systems: Apple iOS 12.2 or higher, Android OS 7.0 or higher, and Windows 10 version 1607.0 or higher. For the latest list of devices that support the Fitbit app for Android, see Which phones and tablets can I use with my Fitbit watch or tracker?
Please keep in mind that when a device is not supported and does not meet the require OS we cannot guarantee its functionality with the Fitbit app. It might work at a certain time and then it can stop working out of nowhere after an update. This is because the app is not optimized to that device and any change could impact the performance.
We routinely test new devices to ensure full compatibility with Fitbit devices and the Fitbit app, and are constantly working to confirm compatibility with new phone models. Be sure to verify that your phone or tablet meets the minimum operating system requirements.
