10-06-2022
17:27
08:16
10-06-2022
17:27
08:16
I recently transferred my Fitbit versa 2 to my son. I was able to set the device up and pair it successfully a week ago. Since then the versa 2 had not updated. I tried to pair again with no luck. I turned off the Bluetooth, turned off my phone, reset the versa and nothing. Please help
10-07-2022 08:18 - edited 11-21-2023 05:34
Hi there, @Cmahurin. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with the Versa 2 before reaching out.
I agree with @SunsetRunner. It seems like the Versa 2 is still linked to your phone's Bluetooth. With that being said, I suggest trying the following:
Hope that helps.
10-07-2022 06:55
10-07-2022 06:55
Hello @Cmahurin
🤔 Is it possible (since you gifted your Versa 2 to your son) that the Versa 2 is still showing up on your phone as a connected device and causing conflicts?
If that’s not the case it might help to reset up the Versa 2 again on your son’s mobile device again as a new device. He won’t lose any data he might have collected during that week he had it syncing successfully. That data is being held on the Fitbit Servers. But the data he collected after his last successfully sync will be lost.
Here is how you set up your sons Versa 2 again as a new device. Please follow these steps closely and do not skip a step:
😃 Hopefully this gets your sons Versa 2 up and running again. Please come back and let me know how it goes
Best Answer10-07-2022 08:18 - edited 11-21-2023 05:34
Hope that helps.
