09-13-2019
06:35
11:58
LizzyFitbit
09-13-2019
06:35
11:58
LizzyFitbit
Everything is connected Im getting text and phone calls and my steps sync with the app.
The Spotify won't connect Ive did a reset
I just dont know what more to do
Also I dont have the 7 stars when you swipe up and it wont let me add it
Help me please and thank you
Moderator edit: format and updated subject for clarity
01-15-2020 11:21
01-15-2020 11:21
So nothing I did will make Spotify work with my Versa 2 I reboot everything I've logged out and logged in sometimes it says Bluetooth is unavailable sometimes it says no internet connection any thoughts
01-16-2020 11:42
01-16-2020 11:42
Are you going to the Spotify settings in your Fitbit app and logging out and back in there?
01-16-2020 12:53
01-16-2020 12:53
Every time
Short term fix
Try spotify HR app!
01-16-2020 12:55
01-16-2020 12:55
What is spotify hr
01-16-2020 12:56
01-16-2020 12:56
Yes I am
01-16-2020 14:51
01-16-2020 14:51
Another spotify app, not as fancy but it WORKS
01-16-2020 15:20
01-16-2020 15:20
How do I get it
01-17-2020 02:21 - edited 01-17-2020 12:32
Another disgruntled Versa 2 owner here
Only fix i have for the Spotify App is to open the Fitbit app on my phone, log out of Spotify app and log back in, only then will it allow the phone app to connect, every time I want to use the app
Come of Fitbit, sort it out, its clearly a faulty app, and one of the big selling points of the phone
And yes i know there is Spotify HR, but come on, it looks like it was made by a child, and has so little functionality compared to the official app, as when the official one works, it works great, but it only ever works once, then you have to go through the whole rigmarole again
Fitbit Versa 2 on Android (Moto G7 Plus)
01-17-2020 11:22
01-17-2020 11:22
01-17-2020 12:16
01-17-2020 12:16
I initially was not able to recieve any message on my Fitbit Versa 2. Once I powercycled it, I was able to get them and so was my wife.
01-17-2020 12:34
01-17-2020 12:34
Yes Falcao, same here ( I just edited my comment), I have to log out and back in each time I want to use the app
Surely that alone says the app is massively flawed......... Sort it out Fitbit
01-17-2020 18:50
01-17-2020 18:50
i was having the same problem.
try logging out of your Spotify acc on the fitbit versa app then logging back in.
that worked for me 🙂
01-18-2020 05:53
01-18-2020 05:53
Temporary fix!
We have tried everything and you will be in our same position and waste time too!
There is no fix! Fitbit does NOT care, spotify does NOT care.
01-18-2020 08:34
01-18-2020 08:34
Had the same problem, the problem was that i was offline on the spotify app on my phone (Oneplus 6). So when I went online it started to work.
01-24-2020 04:54
01-24-2020 04:54
Same here ... I uninstalled Spotify and reinstalled. It worked !
01-26-2020 11:01
01-26-2020 11:01
Alright everyone this worked for me and hopefully you can try it. First try restarting both phone and fitbit if that's doesn't work then go to plan b. Plan B consists of going to your Fitbit app. Then click on your device and find it's apps. Once you do that try to find Spotify and there should be a little gear icon. Click that and it'll bring up your account. Log out of your account then log back in and out of the 5 times I've had to do this it works every time. There seems to be an issue with the Fitbit saving your account info or something but hopefully this helps you guys out. Have a great day!
01-26-2020 11:51
01-26-2020 11:51
Yes this does work, but only once
You shouldn't need to do this every time you want to use the Spotify app, this has been going on long enough now for Fitbit to have found the fault and fixed it, but they don't seem willing to do anything about a clearly fatally flawed app
01-30-2020 15:01
01-30-2020 15:01
I have the Versa 2 and my texts are just fine. Took a bit but you have to have your phone setup to where it will show the texts while locked in a preview mode for the Versa 2 to work properly. The voice to text is a little clunky and does not alway translate well but does the job while my hands are busy. Also really long texts (medium long texts as well) will get cut off.
02-07-2020 15:35
02-07-2020 15:35
I just fixed mine. Allow pop up notifications and all permissions. Then go onto the Spotify app on your phone. You should get something on your fitbit to pop up after with your phone name. You may need to restart your phone and/or spotify app. Permissions and pop up notifications on my end seemed to be the issue.
02-16-2020 00:15
02-16-2020 00:15
Hi everyone! Has another user suggested in the comments, just setup everything like you've done and restart your phone ;). I have a Google pixel 2 and now everything is working! 🙂
