01-04-2022 15:08
01-04-2022 15:08
My versa two isn't recieving any notifications as the Fitbit app says phone needs a restart but I've tried restarting the phone, the watch and the app and it still won't send me notifications
01-05-2022 02:12
01-05-2022 02:12
I have been having the same issue, for almost a week now, as well.
Best Answer01-05-2022 12:27
01-05-2022 12:27
Hi did you get anywhere with this issue? Same thing has been happening to me after a week of it working. I have now not had notifications for a week!
Best Answer01-05-2022 13:00
01-05-2022 13:00
01-05-2022 13:53
01-05-2022 13:53
So I decided I was going to go into the app settings to clear the cashe or whatever it's called and noticed that the microphone and physical permissions weren't on so I turned them on and it started working.
Best Answer01-05-2022 23:52
01-05-2022 23:52
Driving me nuts, mine keeps coming and going, the restart your phone thing is bull**ahem** it would seem. Mine stopped yesterday again and I had done nothing different. 🤬.
Best Answer01-08-2022 01:18
01-08-2022 01:18
I had a tip from a friend to delete and redownload the app so I did It this morning it now seems to be working
Best Answer01-08-2022 08:32
01-08-2022 08:32
Best Answer01-09-2022 09:08
01-09-2022 09:08
I was having the same issue and got the notifications re-enabled, however versa screen doesn't wake up or vibrates.
When I wake up the watch by pressing the left button, I can see the notification. Any help would be useful.
Best Answer01-10-2022 09:55
01-10-2022 09:55
Was this settings on your phone? Or in the fitbit app?
Best Answer01-10-2022 11:48
01-10-2022 11:48
I just uninstall the app, then just "Allow" everything when I reinstall it, but no matter how many times I do it it only lasts a few hours then gone again. I give up at this stage. Hopefully you have better luck. 👍
Best Answer01-10-2022 12:57
01-10-2022 12:57
It was in the settings on the phone in the Fitbit app.
Best Answer01-10-2022 13:01
01-10-2022 13:01
I took screen shots but idk how to insert them.
Go to your settings and select the apps
Select the Fitbit app
Go to permissions and make sure everything is under accept
01-10-2022 16:43
01-10-2022 16:43
Thanks for replying. I have tried everything imaginable and even chatted with customer support for 30 minutes today with no resolution. Very frustrating. I don't want to buy a new one, but I rely on the notifications soooo much! I appreciate the help!
Best Answer01-12-2022 06:47
01-12-2022 06:47
I finally ended up resetting my fitbit to factory standards and resetting it up again and now I'm getting notifications. Kind of a pain, but worth it to have notifications back. good luck.
Best Answer01-14-2022 13:37
01-14-2022 13:37
I just resolved this issue with mine, I hope this helps y'all too.
1. Open your app and go to your Today page.
2. Click your profile pic in the top left.
3. Click on your device.
4. Under "General" click Notifications.
5. Check your call, text, calendar, and email settings to make sure they're correct.
6. Click App Notifications and make sure everything is checked that you are supposed to get notifications for.
This fixed it for me after HOURS of turning my phone off and on, deleting my Fitbit app and redownloading it multiple times, and restarting my Fitbit repeatedly, all in various orders.
Hope that helps ♡♡
Jenn
Best Answer01-14-2022 13:51
01-14-2022 13:51
