04-12-2021
21:03
05:51
04-12-2021
21:03
05:51
My Versa2 won't hold a charge longer than 2 days. Is there any way to get a longer charge?
04-13-2021 05:51 - edited 10-25-2023 05:40
Hi there, @Ginny1942.
As you may know, your Versa 2 battery should last up to 6 days. However, as with other electronic devices, the battery will depend on the features and how often they're used, such as the GPS, Spotify app or the Always-On display. While this doesn't mean that you shouldn't use them, please take into consideration the conditions that impact your watch's battery.
That being said, I'd recommend to change the clock face to one designed by Fitbit and please confirm if you've followed the tips and recommendations to maximize your watch's battery life described here.
Hope that helps.
Hope that helps.
