09-15-2022
20:10
06:03
09-15-2022
20:10
06:03
My Versa 2 will not let me select an exercise. It’s like the screen gets stuck. I have rebooted and nothing. Please help!!! What do I need to do? Battery is fully charged.
09-16-2022 06:05 - edited 08-18-2023 05:33
Hi there, @Aspriggs. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa 2 before reaching out. @JohnnyRow Thanks for your help.
Since the restart you've done didn't work, please try to change your clock face. If this fixes the issue, you can change your clock face back to the original clock face.
Best Answer09-15-2022 21:04
09-15-2022 21:04
Have you tried a restart ? A good easy first step for any problem; sometimes helps and never does any harm.
Best Answer09-16-2022 05:28
09-16-2022 05:28
Best Answer09-16-2022 06:05 - edited 08-18-2023 05:33
