Versa 2 won't pair back to my phone
ANSWERED
Due to not working uninstalled versa 2 from mobile now unable to reconnect Versa 2 to mobile
1 BEST ANSWER
Accepted Solutions
Hi there, @MCGranny5. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa 2 before reaching out.
To solve this issue, please follow the steps below:
  • Unpair your Versa 2 from your phone's Bluetooth and also make sure it's no longer connect to your Fitbit app.
  • Force quit the Fitbit app.
  • Turn off the Bluetooth.
  • Turn on the Bluetooth.
  • Set up your Versa 2 again.
  • If there is no connection, restart your Versa 2.
If you can't get started with your Versa 2, usually a missing requirement is the cause. Carefully review the requirements provided in the help article Why can't I set up my Fitbit device?
If you continue having syncing issues after pairing your Versa 2, see Why won't my Fitbit device sync?
Hope this helps.
4 REPLIES 4
Hope this helps.
Thank you so very much Fitbit now working 😀
Have a great day
@MCGranny5 Awesome! I'm glad to hear the issue is solved now.
I would like to invite you to visit our Health & Wellness where you will find great tips and encouragement from other members.
Hi I'm having the same problem.. my Versa 2 won't reconnect to my phone. I have a Samsung galaxy z flip 3 . It says its Doune my versa 2 but then won't connect 😕 I've been trying now since after Christmas and raised 2 cases .. tried all the trouble shootings but not worked..what else can j do ..thanks Tracy
